YouTube HDR content is finally available!
You will find a playlist here. However, these clips will be played as SDR on Sonys for now.
With youtube-dl you can find vp9.2 encodings for those clips:
330 webm 256x144 144p60 156k , vp9.2, 60fps, video only, 2.38MiB 331 webm 426x240 240p60 256k , vp9.2, 60fps, video only, 3.87MiB 332 webm 640x360 360p60 485k , vp9.2, 60fps, video only, 7.35MiB 333 webm 854x480 480p60 909k , vp9.2, 60fps, video only, 13.83MiB 334 webm 1280x720 720p60 1991k , vp9.2, 60fps, video only, 28.18MiB 335 webm 1920x1080 1080p60 3201k , vp9.2, 60fps, video only, 49.70MiB 336 webm 2560x1440 1440p60 11166k , vp9.2, 60fps, video only, 170.23MiB 337 webm 3840x2160 2160p60 20122k , vp9.2, 60fps, video only, 335.45MiB
Those are webm however which the native Video app won't play.
We will see whether we will get support for it soon, even for the early 2016 models with the old MediaTek SoC from last year. At least Sony promised that back at CES:
@Jecht_Sinschrieb:Is it something to do with VP9.2?
One important fact could be that those demo clips are full 16:9 without black bars. Your TV without local dimming isn't the best HDR set. So the black bars might give it a hard time (washed out look)... Then also, it is 60p with lots of bits being thrown at it. Plus they usually pick nice and colorful sceneries for those demos . Nothing to do with VP9.2...
Yeh, demos are usually highly tuned, I've not got Netflix so cannot compare how good they look. I have always been impressed with Amazon HDR stuff though. Just not enough 4K HDR stuff there.
Since my Sony replaced the Amazon Video app with the Prime Video app from the Play Store, I am not seeing any 4K content on Amazon anymore anyway...
Is your Amazon app still called Amazon Video with the black logo? Or has it been replaced by Prime Video app with the blue logo?
Last time I checked was last Thursday. It did not show me the 4K HDR tiles (e.g. from The Grand Tour) anymore. Might also be a regional problem. It has been reported on German forums by others too.
Yeh I had the same issue, you have to manually scroll down pages to find the 4K stuff, it's rediculous. Using the search does not result in 4K. So yeh it's a case of just scrolling down the main screen and finding the 4K section.
i have the same problem,
i tried 3 days to contact amazon and find a solution... fist i was in denmark, then UK, ...
You can play 4K videos in the Amazon Prime App, but it is very difficult to find it.
Try to Search for "UHD", you will find some Videos but not all
or you search on the Amazon Webpage and add the Video to the Watchlist
I think Amazon hide the 4K contents to save Bandwith 🙂
best regards
Silvio
@stormyukschrieb:Yeh I had the same issue, you have to manually scroll down pages to find the 4K stuff, it's rediculous. Using the search does not result in 4K. So yeh it's a case of just scrolling down the main screen and finding the 4K section.
Thanks. Found it. They really seem to be hiding 4K stuff now as you really have to scroll a long time to get there.
