Try settings-apps-all-media storage.Force stop and clear data.Restart your phone.
If you go to settings-apps-all,select some apps and move them to internal storage.
I have all my apps in SD card but still when any updates come for pre installed apps it's saying running out of memory.
as you said I tried to move some internal apps to sd card or internal storage but it's not showing any option.
in 20K range xperia C is a flop model.
Is there any permanent solution?
or else am thinking to change my handset.
Thanks
Raghu
That is not ok,it seems that C is the only Xperia that can move apps to SD.
Hi
I have moved all apps that I can from my internal to my sd card and still i cant download any apps larger than 10mb and i have only 87mb on my internal, i have more than 14gb open on my sd card and my phone is set to install on my sd card, it still doesnt work, i have resently set my phone back to factory default but i can still not download big apps. How can i get my phone to install only on my sd card so that i can actually get apps on my phone?
