- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
[0] Network 0
[x] Network subnet 0
[x] service provider 0
[x] corporate 0
[x] sim 0
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Naw,
I suggest you contact them and advise the following.
" I have entered my Network unlock code to many times, now I am unable to unlock my phone from the network carrier it is locked to. I need the handset to be reset so I can enter this code again to unlock it from the network."
This should hopefully work, however you will also need to obtain a different code from the network carrier as it seems the one they supplied you original did not work, due to the fact that it is now locked.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
http://support.sonymobile.com/global-en/contactUs/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The service agents should be able to reset the counter for you and after that, you could insert or buy a new code from your network or so.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, it's a technician at our service center. I can't say for sure if they are able to assist you since warranty and repairs may differ from market to market. This is something that you need to raise with your Local support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No, it will not help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
