Can I permanentyl remove audio in playmemories or sony action cam movie creator
duckman1
Im pretty new to all this. I have a sony action camera. Got some great footage over the weekend but some unwanted swearing. Is there any way to remove this audio permanently ?
Thanks
1 REPLY 1
profile.country.en_GB.title
Watashiwateshdes
Contributor
Just been playing around with the new Action Cam software and its pretty cool for things like joining clips and editing the slow motion but I cannot see any options of removing audio.
If you are uploading to YouTube, you can replace the entire audio with music from their online selection. Other than that, I would possibly consider some more advanced video editing software since the stuff provided is pretty basic.
