Wii connection.
HazeyBlue
Wii connection.
Can anyone help me with connecting my Wii to my new Sony Bravia please. I’ve got it connected via the grey red, white and yellow ports but I have no idea what to press on the remote to get it on the TV. Internet search has proved fruitless. Please use simple language I am by no means a TV expert.  Thank you.
7 REPLIES 7
You have connected the wii via the composite cable, so find the "input" button on your remote or TV and change to "Composite" if it's there.
HazeyBlue
Thank you for the reply. When I press the input button the choices I have are:
Streaming channels
HDMI1
HDMI2
HSMI3 / ARC
Virgin media
screen mirroring
There is a selection for AV/component but it is greyed out?
Marino.Manolo
Your TV model?
HazeyBlue
It’s a KD43XF8796
Thank you
Marino.Manolo
And, excuse me... Can you check "Virgin media"?
Have you connected at the right Input?
Screenshot_20200403-172947_Acrobat for Samsung.jpgScreenshot_20200403-172947_Acrobat for Samsung.jpg
HazeyBlue
Whoop thank you. It’s working now. Something so simple. I had the yellow in the wrong port!
Marino.Manolo
I suspected it... 🖖
