Hi Samaras1888, have you checked you do have the call logs hidden? Click on phone then on the three blocks on the bottom right of your screen and you should find the option to Show call logs.
Hi Samaras1888,
Welcome to the Sony UK community The best place for queries about the Xperia phones is the moblie forum, which you can find here: http://talk.sonymobile.com/
Hopefully someone will be able to help you soon!
Clarissa
you can change the call settings..
