Firstly great little compact Hi-Fi.
What can i do about DAB not working. I'm a tech so don't insult me with baby troubleshooting.
GT
Hi GT
WiFi extenders have been known to interfere with DAB signals, even screen them completely. Could this perhaps be the issue, assuming you've set your X7CDB up for optimium WiFi signal?
Apart from trying the HiFi in another location in the house, the only other thing I can think of is to check whether DAB reception is possible with another device.
Mick
Hi GT, sorry to be a while getting back to you.
I can't imagine this is a fault, if as you say you are able to get channel listings.
I think it's fair to say DAB on this unit may need to be ideally sited to work as well as a dedicated DAB radio. It's probably down the lack of a good-sized antenna, which of course your cars will have and would explain why they receive such a good signal. With the unit being designed primarily for compactness and multi-functionalty, it does – as you have amply pointed out – fall a little short in some departments.
I'm guessing you are using the supplied FM antenna as well as the little pop-up one? Some of our regulars here have worked out a hack to boost their reception. Not completely elegant, but it may help.
Best wishes
Mick
