BDP-S370 not reading NAS drive correctly
profile.country.en_GB.title
lunchmoney
Hello,
I have a BDP-S370 and a Seagate Go-Flex NAS drive.
The NAS has lots of video content stored on it that can be read by my Win7 PC and laptop.
The BDP, however, can only see and play some of the files. I recently had a clear out of the drive, but the player is still saying the deleted files are still there. And cannot see any new ones I have added.
The files are all the same format.
I'm going nuts trying to get the player to read the read the NAS correctly!
er... Cant think of anything else to add right. Any help would be appriciated and I will try to answer any and all questions that I can, but please bear in mind I'm not a fan of jargon and acronyms. Please use plain english :slight_smile:
21 REPLIES 21
lunchmoney
I wouldnt say I dislike Serviio, it just didnt do anything useful for me.
As for connecting via a USB cable, I had not considered it as I have no spare USB cables :slight_smile:
I'll pick one up on the way home from work this evening and let you know.
lunchmoney
I plugged a USB in to the BDP and the NAS, switched then on and waited for the results.
Nothing.
Additionally, the player is now picking up my PC as "Serviio (PC)". Which is interesting as I removed the Serviio software!
lunchmoney
the links of the deleted files still reside in the SHARE folder
When you browse the NAS from your BDP it read this share folder (not the HD itself)"
So what can I do to amend this? Since nothing else is working......
KDL-CX520
Hello,
You stated :
i plugged a USB in to the BDP and the NAS, switched then on and waited for the results.
Nothing.
what do u mean by nothing? did you go to menu> video or photo or audio> select you NAS which is the USB device
You should see files on your NAS (please refer to page 15 in user manual)
lunchmoney
After connecting the NAS and the BDP via USB I switch them on. No new icons appeared, no USB selection appeared. And to top it off, when selecting the NAS drive from the usual list it now says "Unable to find server. Please peform network diagnosis...."
I've checked the manual and it gives nothing new away that I havent done.
I'm trying everything you suggest several times and nothing seems to be working. :slight_frown:
KDL-CX520
Sorry to hear about that, just i am trying to help
An additional information, (but i am not sure if it is applicable to BDP or not), that information says Some Sony devices can not see the USB unless it is formated by FAT32 or exFAT
lunchmoney
I know and I appriciate it the help.
I'll try moving all files off the NAS, formatting to FAT32, then putting them back.
I'll update once this is complete.
lunchmoney
Further to formatting to FAT32........
I am currenly moving files around (it take a while to shift a TB of data :smileyhappy:) and whilst doing so I thought I'd check how to format the NAS, as there is no "format" option when I right click on the drive icon.
A lot of advice appears to be to use the Disk Management tool, however the NAS does not appear on this.
Is there another way to format NAS drives that I am missing?
Also I am slightly concerned from reading that FAT32 set up is limited to 4gb files. Does that means the HiDef files on the drive will not work?
KDL-CX520
Hello again,
i think any drive can be formated, may be it have some file protection software which prevent the format, check the company website for your drive , sure they provide some procedure to do it. Or google it
Yes the FAT32 is limited to 4GB for a single file, only exFAT or NTFS can accept bigger size, Some Sony products not see the NTFS drive when connected to USB port
I am sure your BDP is ok and the problem located with NAS itself, or some configuration related to your home network setting
lunchmoney
OK, I moved all files off the NAS and started the format........
However the drive crash.  I tried to fix it (in my limited knowledge) but couldnt. So I took it back to store and they tested and said the drive had failed. And swapped out for a new one. A different make, WD. Have hooked it up and put some files on it and BDP sees them all.:smileyhappy:
So thanks again for your help, it really was appriciated. The issue has been solved by a hardware failure and replacement:smileysilly:
