Hi i have a home cinema blueray system BDV-E2100 connected to sony tv KD-55XE8596 via optical cable and it takes approx 35 seconds to play any sound when its turned on ?
Hi barrie1007,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Hi Barrie,
Do you mean there is a delay of 35 seconds between what you see on the screen and what you hear? Does the same thing happen if you try connecting via HDMI?
Win_88
