Bluetooth issues with BDVN7100 system
Help! My Bluetooth suddenly disconnected from my iPhone during playback and now I can't reconnect, with any phone! It just says unable to connect. Still able to connect via YouTube so this is very strange...please help!! Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
In regards to Speaker Illumination, see below:
EDIT: Beat me to it Jumpsuit
7 REPLIES 7
Anonymous
Not applicable
Hi there
Try turning all equipment off from the wall for about 2 mins and start again.  Reboot iPhone whilst your at it too
Thanks for reply! Issue fixed - I had to forget the device and then re-pair it from my iphone for some reason, working fine! Strangely enough now my one of my speakers is constantly illuminated when the unit is turned off as if its still getting power - only way to turn it off is by unplugging from mains, not ideal!
PS does anyone know how I can change my username before I get blocked?!
jumpsuit
Hi there whatis*******available and welcome :laughing:
I guess you were frustrated at your original name choices already being taken? lol
I belive they are working on your user name 'problem', but in the meantime you could also pm a Community Manager here e.g. Drewde.
As you'll see from your profile settings you personally can't change your name, it has to be done for you.
Please don't answer this post as it will then advertise your name at the top of the recent posts list lol.
Anonymous
Not applicable
Hi there
Drewde
Administrator
Please PM me your preferred new username and I'll get it changed.
Thanks.
jumpsuit
and no, you can't have 'whatisnot*******available' either lol :wink:
Jonnie1266
Contributor
Hi "whateveryournewnamewill be",
Interestingly a new software update became available on 26th June, part of the update is to improve Bluetooth playback. See here: http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-tvhc/sony-bdvn-firmware-update-v17r0187/BDV-N9...
I have the N9100W (without the speaker illumination) but the update covers the N7100WL also, I updated mine successfully today.
If it ain't broke don't fix it
