All of a sudden there is no longer any sound from my Blu-ray player, while using coaxial to my Yamaha 5.1 amp . It worked in the beginning , now nothing. What’s happening 😩
Yes, tried that no joy , using HDMI instead , sounds better anyway, thanks
Hi MikeSmartv,
Welcome to the community.
Have you tried a factory reset?
Best wishes,
M
