annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Sony STR-DA2400ES - Display Problem
Hornets_Nest
Nouveau
I know this is an old receiver but it's served me well
There is one problem - every now and then the display goes blank, sometimes it will reset itself but then sometimes I need to do a reset to factory settings and the display comes back straight away
Balises (2)
2 RÉPONSES 2
Pascale_F
Moderator
Hi Hornets_Nest,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Win_88
Spécialiste
Hi there,
It's true that the receiver is a bit on the older side. So I'd say your best bet would be to contact your closest service centre. you can find it using the locator here:
https://locator.sony/en_GB/servicecenters
Win_88
