12,944  Views
The Sony Channel Editor tool allows you to re-order your channel list via your PC. Simply download the list onto a USB stick, edit the order and then upload it back to your TV.
Restrictions
  • Only for use with TV sold in Europe. Not all models are sold in all countries.
What You Need
How to use the tool
You can modify the channel list of your TV in three simple steps:
  1. Export the channel list from your TV.
  2. Modify the channel list on your computer.
  3. Import the modified channel list to your TV.
For more information, please follow the steps below.
  • Exporting the channel list from your TV:
    • Insert a memory stick into a USB port on your TV.
      a) For Sony’s Android models go to:
      [Home] > [Settings] > [Channel Setup] > [Digital setup] > [Technical Set-up] > [Program List Transfer] > [Export]
      b) For Sony’s non-Android models go to:
      [Home] > [Settings] > [System Settings] > [Channel Set-up] > [Digital Set-up] > [Technical Set-up] > [Program List Transfer] > [Export]
    • A file called “sdb.xml” will be copied onto your memory stick.
  • Modifying the channel list on your computer:
    • Insert the memory stick with “sdb.xml” into a USB port on your computer.
    • Launch the Channel Editor tool and open “sdb.xml”.
    • Re-order the programmes in your channel list.
    • Save your modified channel list onto “sdb.xml” in the memory stick.
    1. Importing the channel list to your TV:
      • Insert the memory stick with the modified “sdb.xml” into a USB port on your TV.
        [Home] > [Settings] > [Channel Setup] > [Digital setup] > [Technical Set-up] > [Program List Transfer] > [Import]
        [Home] > [Settings] > [System Settings] > [Channel Set-up] > [Digital Set-up] > [Technical Set-up] > [Program List Transfer] > [Import]
      • You will have the new channel list after your TV reboots
    17 Comments
    sgsony
    A manual and complicated process.
    can channel list be rearranged direct on tv settings, I have an older tv which can.
    David_Lamport
    Is there a Mac OSX application that us Apple users can use.
    David_Lamport
    Apple Mac computers dont work with .exe files! Apple Macs use a dirrenet operating system called OSX. Is ther a Apple mac version available?
    Waalpaul
    When I insert a USB Stick (Tried several formats) in my USB connection on the side of my  KD-55A1 and register this USB stick (Not format it) it all goes fine. The TV regonizes the stick and I can export. However next I goto export channel settings exports, the TV exports the data to my connected HD (Bottom HDD USB connection). I can see the data on my HD but why does it not export to the USB Stick (or give an a choice where to save it)?
    EdwinaU
    Moderator
    Hi Waalpaul,
    We will take a look at this and let you know what we find out, and maybe another member will have some advice for you.
    Best wishes,
    Ed
    batee5
    Specialist
    Hi Waalpaul,
    Welcome to our community!
    Could you try again but don't register the USB stick on your TV? Usually, operations like playing back content from a USB stick or exporting channel listings to a USB don't require registration.
    Let us know if the same issue happens when you don't register the USB stick.
    Regards,
    Batee5
    gene21
    I just downloaded the Sony Channel Editor for IOS
    Put it in my Program list
    Try to open it, but the app don't work.
    Somebody with same problems ?
    Greets,
    Gene
    mawisem49
    Following all the instruction given by Sony.
    Downloaded and ran the Mac app which is available. looks a bit rough around the edges but I'm guessing it works... I'm guessing.
    When Inserted a USB disk into USB slot 1 on the 2015 Bravia running Android TV picked up and gave me options.
    Look at Pictures
    Watch Videos
    Register disk
    ETC.
    I went back.
    Having already read what Baatee5 wrote back in July. I did not format the disk.
    I then procceded as instruction to.....
    'Programme List Transfer' is greyed out and cannot be selected.
    So.... I take out the USB and push it back in. Again, get the message asking what to do, so I try with the format to use as storgae.
    This time I go back to 'Programe List Transfer' and hey presto I can export the information onto the USB Disk. I remove the disk from TV and insert into Macbook. Now I get a Mac message comes up to say disk is not readble and need to be initialised!
    I then find a windows pc plug the USB in and same deal, have to format the disk.
    I'll also when trying install the PC software of Sony Channle Editor that it failed at every attempt.
    Why is it Sony makes everything so conveluted and fails. The day I bought the TV I was so excited, but its been nothing but pain, then Sony killed the remote app which was the only stable and useful thing the TV had to offer.
    I don't think I can take any more and a new Panasonic coming up soon...
    Another hour of my life I won't get back! Total Nonesense.
    Mattail
    I'm experiancing the exact same problem as user on my Sony AF8.
    profile.country.IE.title
    davidcora321
    I install the editor on my PC using Win 10, All seems fine until I launch the programme, the programs dose not launch just files appear. no actual program
    davidcora321
    Hi,I'm I doing something wrong Ibhsvevthr channel list on “sdb.xml” in the memory stick. Importing the channel list to your TV: but the modified channel list dose not update the channel list on TV ,the old channel list is still active. I check the sdb file again on my PC and it has the new channel list, but when I try to update it on TV it states that it has overwritten the existing file but I still have the old chsnnec list. Can you help pkeaep
    AMShieling
    davidcora321  - I think you may have solved this one, but you need to re-boot your TV in order to get the new channel list.
    AMShieling
    Does anyone have any idea why I don't see the encrypted channels with a $, as stated in the documentation. Also, I am assuming that any channel without a name is a data channel?
    petemech
    does not work on my 49XG9005
    Even with latest firmware update !
    recKISS2S
    I have the same Problem as AMShieling: I don't see the encrypted channels with a $, as stated in the documentation.
    It would be nice to get some help.
    montyray
    It would be nice to have a "PRINT-OUT" facility with the ability to invert the printed page currently mising on version 1.2.0.
    It's all very well for Freeview where the guide is sufficient and not too slow, but on satellite where you can get up to well over 1000 channels it would be nice to be able to print out the complete channel list as an aid memoir the make your selections about what to keep and what to delete.
    montyray
    Following on from sgsony's comments about older TVs having the ability to rearrange TV channel listings, I had a Panasonic Viera Neo Plasma that was able not only to do this but also to update channels as and when satellite channels were moved to alternative transponders keeping the preferred channel number. It also showed all radio channels in a seperate guide. My Sony Android TV is very basic in this regard.
