- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
hi friend, need help on setting ringtone...
facing cant read chinese when setting ringtone...(remarks : but can read chinese thru the memory card)
menu > setting > sound& display setting > phone ringtone > music library
some of chinese can read, but some cant...may i know how to reslove it???
and this setting ringtone method is too diff...got another alternative way???
thanks for the help....
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you download Handcent SMS texting app, which is a great text app in its own right, one of the 'side effects' of it is that it allows you to select non-android system ringtones. When you select Ringtone in Sound & Display settings you will get two options Android System and then Select Music.
The other option is to try an app like Zedge which has hundreds of ringtones and wallpapers. This also gives you a similar option when selecting ringtone, so actually on my phone I have three options to select... Android/Handcent/Zedge.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I do not know whether you can do this (for android 2.1 on mini pro). While listening to a song, press MENU and select Set as ringtone. Have a try.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What you can try is this:
If you have installed ASTRO File Manager from Android market, go to the location where your tones/songs are present, long press on the a tone, a pop-up with 2 options come:
1) Play
2) Set as Ringtone
select the 2nd option. Hope this solves your problem!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hmm, this method cant work
anyway...thanks very much...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
okok, i will try it
is it astro file manage is one of type "file manager"..cos i downloaded one "file manager" from android market...but it do not hv feature as you say below..
thanksssss
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The app that i mentioned was ASTRO File manager. Just search 'ASTRO' on the search bar in the market. If you are not getting it, it just means that you are in a region where that app isnt available.
