KDL-37P3020
profile.country.en_GB.title
ldevlin90
KDL-37P3020
I have a Bravia KDL-37P3020 & DVD recorder HDX995.
My problem is - everytime i record or watch either recorded programmes or DVD's - in the top left hand corner of the screen it says
recorder 1 (HDD/DVD)
(box like tv shape) 4
1080i/50
Its so annoying and I can't find how to get it off - i have reset the TV and reset the DVD recorder but its still there.
I am also posting this in DVD section as I am not sure if its a TV or DVD problem!
Please help ASAP
1 REPLY 1
StartTheCar
Contributor
Hello, welcome to the Sony Forums
For the TV, I would try the i+/? button which is used to display programme details and other info on the screen,  Page 10 of the user manual should have more details.
I believe the 'info' button on the DVD recorder does something similar.  Worth a look if the above doesnt clear it
Regards
Lee
