Mains cable/plug for KDL48WD653 TV
Noddy64
Ontdekker
I've just moved house and misplaced the power cable for my Sony Bravia KDL48WD653 Smart TV. I also have a 55 inch Google Sony Bravia, but it has a different mains cable. I honestly cannot remember what the 48 inch TV cable actually look like, but I think it has a box where the plug part of it with a kettle type connection fits into it. I've looked on virus sites,  asked Sony services, who gave me a model number, but the transcript didn't come through for me to note this down. Can anyone help with a photo, or better still a replacement that doesn't cost the earth, as some are over £100. Your help is very much welcomed.
2 ANTWOORDEN 2
LightFoot
Specialist
Hi @Noddy64   There appears to be lots available from a quick Google, the first one on the list (loads of others).
https://www.less4gadget.co.uk/new-sony-kdl-48wd653-ac-power-adapter-psu--p1477?gclid=CjwKCAjwh4ObBhA...
If you are looking for a genuine one, then try eBay used.
Noddy64
Ontdekker
Thank you. I managed to purchase one off eBay. No doubt the original one will turn up now. 👍
