Hi Guys
I got a new KDL-42W829B yesterday, set it all up fine, everything working.
Today Netflix app isn't working - TV says update required, I click to get update then says no new version avaliable
its then stuck in this loop
Other online apps are fine, firmware is up to date (downloaded to USB) Tv said its same version
Reset to factory settings, still no joy
Does anyone have any ideas ?
Thanks
Hi having the same problem everytime i select netflix it says update but its says no newer version detected.
I'm also having this issue - KDL-32W705B.
HI all
Just to let you all know, there is very little information at this stage. However Sony is fully aware of the issue and are investigating at this stage.
Cheers.
Same problem here - contacted Sony over the phone - who said they would e-mail me with a list to go through - no sign of that as yet - and I don't hold out a lot of hope - looks like the last "fix" has broken something else
Same here KDL-W42705B.
I also have the KDL-42W829B and netflix was working fine yesterday but is coming up with the update message today. I have checked and I do have the latest update which is why it can't find it - very frustrating when you're paying for a service you cannot use!
Same issue TV model 55W950B, repoted to sony this morning, they said they will get back to me in next 24 hours..
