Hi Guys
I got a new KDL-42W829B yesterday, set it all up fine, everything working.
Today Netflix app isn't working - TV says update required, I click to get update then says no new version avaliable
its then stuck in this loop
Other online apps are fine, firmware is up to date (downloaded to USB) Tv said its same version
Reset to factory settings, still no joy
Does anyone have any ideas ?
Thanks
Exactly the same issue. KDL-50W815B. Very frustrating, can't believe the issue hasn't been fixed yet!
KDL-40W605B here. Same issue. Same firmware.
Hope it doesn't take as long as the old PDR took!
Luckily, I can run it through the PS3 or I'd have a child mutiny on my hands.
Hi all
I have received no new updates as of yet. However sometimes problems are not as 'clear cut' or easily resolved as hoped. It also takes time for engineers to gather information and investigate as well as trying to replicate the problem. Once the problem can be replicated, its then they can work on a solution.
It may not even be Sonys problem, and that would mean working with other companies, which brings a complexity of its own.
Thank you all for your continued patience.
Cheers.
Me too on KDL-40W605B
Same problem here.
Model Bravia KDL42W8
Same here
'Your Sony Bravia TV needs a system update in order to receive more new and exciting content'
Clikc 'Update now'
Download software
Newer version not detected:smileyplain:
Same thing here, Sony kdl-40w605b
Same thing here, KDL-42W705B
