Hi Guys
I got a new KDL-42W829B yesterday, set it all up fine, everything working.
Today Netflix app isn't working - TV says update required, I click to get update then says no new version avaliable
its then stuck in this loop
Other online apps are fine, firmware is up to date (downloaded to USB) Tv said its same version
Reset to factory settings, still no joy
Does anyone have any ideas ?
Thanks
I am facing the same problem on my W955BBU
Same problem on my KDL-42W706B come on sony sort this out.. I am having to go back to my apple TV and i hope that gives you a problem in terms of the image you want to promote
Here is a response from netflix: Netflix Sauna
It works here too 🙂
Working again :smileyhappy:. Did not have to reactivate or anything.
Wuuhuu! Works for me too!
Well done Sony and Netflix for getting onto this and fixing it quickly.
Thanks.
