Sony Bravia doesn't connect to network
SolihullRog
My Sony Bravia has connected to my network for several years ,but I had a problem.
Now, it won't reconnect.  It connects to wifi, but not to Local network or Internet.
Following instructions I changed the ip address and related settings, and I suspect that that's what broke it.
But I don't know what the original values were.
Is the ip address likely to cause my symptoms?
How do I find out what the ip address(es) should be?
What else could cause my problem?
Thank you.
1 REPLY 1
EdwinaU
Moderator
Hi there,
Welcome to the community.
You could try the troubleshooting tips here and see if they help.
Let us know how you get on.
Best wishes,
Ed
