- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony tv kdl32we613bu won't work properly with Panasonic DVD recorder ex83
Just bought above tv, but anything I try to record onto a minus r DVD comes out as 4:3 screen size. Have checked all screen settings for tv and recorder and both are correct. Somebody out there, please help this technical dunce!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for replying. Screen is set to full. Have tried different formats, including setting 4:3 default to off. Display area is set to normal. Auto format is on, but have tried it on off.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Did you also try setting the screen format to Wide to see if that makes any difference?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the suggestion. Yes, I have tried all settings, but nothing makes any difference.Even a lot of tv
programmes, re entry made ones included default to 4:3 when watched via the DVD recorder
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you I did, but it made absolutely no difference. I do thank you for your suggestion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry to hear you've had no luck @LovesLaboursLost. I don't have any further suggestions I'm afraid!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your help. Not your fault you're not able to help any further. Am so fed up with this tv am thinking of returning it to John Lewis and going to Argos to get a new Panasonic, hopefully that will prove compatible
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I operate a Sony X9005A with a Panny Blu-ray Recorder DMR-BWT720 and in fairness they work together no problem.
It is difficult to understand the issue as you have all the settings both on the recorder and TV set correctly.
When you play back the recording from the HDD how does it appear on the TV screen ?
Regards
If it ain't broke don't fix it
