- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
SWF BR100 compatibility
Does the wireless Subwoofer SWF BR100 connect to any othe brand of TV. More specifically an LG 47LM670T-ZA.
![](/skins/images/12E123D1D0AC24EAD5F6BBAE7DE97773/responsive_peak/images/icon_anonymous_message.png)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Unfortunatley the SWF-BR100 will only work on the selected Sony TVs. This subwoofer has a wireless usb transceiver which other branded TVs would not have the required software drivers installed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok thanks for reply. One reply provided more information than 35 mins on the phone to Sony support
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Your welcome
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi.
I have two Sony Bravia TV’s, are these both compatible with the Sony SWF-BR100
KD-55X8509C and KD-55AG9.
I wish Sony could make it easier to know which models are compatible.
It says KD models are and my KD-558509C works perfectly but I can’t get it to work with the KD-55AG9.
Any advise would be great.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Pockets24 wrote:Hi.
I have two Sony Bravia TV’s, are these both compatible with the Sony SWF-BR100KD-55X8509C and KD-55AG9.
Thank you.
Hi @Pockets24
There shouldn’t be any need to keep repeating the same post, especially on posts that are over 6 years old! If anybody can help you they will reply to your original post.
Just in case you are not aware this is a customer help’s customer community. You are not asking Sony, for that you should contact Sony Support. For example click on Contact Support at the bottom of this page.
https://www.sony.co.uk/electronics/support/accessories-television-projector-accessories/swf-br100
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I keep asking because no one is giving me an answer.
You call this a Community well it’s more bullying than any help.
Thank for the link and hopefully someone professional will be able to answer my question.
I also asked the question again because there are ZERO replies on my question.
