Hello all
I have an ageing Sony Vaio PCG-7162M but i cant find anything about it on the sony website. Is there an equivalent laptop that i could get the downloads for?
Thanks in advance..
Dave
Hi MeesterDave,
You are quoting a model reference that is in fact a chassis reference that can be common to several models. You need to find the Model Name which is probably VGN- NSXXX. You will find this on a label on the underside, in the BIOS and also in Vaio Control Centre under System Information.
Armed with the correct reference you will find the model on the support site.
Rich
Hi MeesterDave,
Rich
PERFECT!
Thankyou Rich.
all sorted.
You're welcome MeesterDave:smileyhappy:
Rich
