Arrrgghhhh - My DVD/CD Drive annoying me (VGN-A417M)
Illusion
PLease help, not really wanting to send it back to sony as i have to use this laptop a lot.
The dvd/cd drive is causing me headaches!!!
the drive will play and write dvd's, but very rarely reads CD's !!!
it makes a noise, like a motor moving, but then it says it can't be read, and hangs my machine ...
I have upgraded to the latest firmware for it...
Is there anything i am missing before i have to send it back ???
Thanks
Paul
5 REPLIES 5
jumpsuit
Are they 'proper' cds or writeable ones that it won't play/read?
Illusion
It is both.. seems really weird, the laptop is only 2 months old !!!
jumpsuit
There could be the usual problems of compatible discs with the machine, I found the cheaper dvds/cd roms are useless.
If its not that, I'll step out of the way and let the 'knowledge guys' give a more technical solution.
profile.country.en_GB.title
kee-lo_
Have you used a lens cleaner?
rich912
Contributor
Is the optical drive a DW-D56A by any chance?
Go n-éirí an bóthar leat
