Bios UpgRrade please help me!Vpcf13b4e
profile.country.ro_RO.title
printularabiei
i have a sony vaio vpcf13b4e and i need too update muy bios but i can„t find any upgrade on sony site!i find one  on ami site but i don„t know exactly what bios to use .CAn anybody help me please?
1 REPLY 1
Blencogo
Hi printularabiei.
As the motherboard is a custom Sony board, you can only use BIOS updates supplied by Sony.  Unfortunately, Sony BIOS is limited in content and locked down by Sony.  Try any other BIOS and you may end up with an expensive doorstop!
Why do you need a BIOS Update?
There is a BIOS update R0190Y9 available on the download site for your model which adds a CPU C3/C6 switch to the BIOS Setup Advanced Menu and also fixes some USB keyboard compatibility issues - look under Windows 7 Latest Downloads here: -
http://www.sony.co.uk/support/en/product/VPCF13B4E/updates
:thinking:
