Blue tooth headset
Sonyfreak
Blue tooth headset
Sony vaio 297 XP with built in Blue tooth
How can I connect a blue tooth headset with mic ?
How can i use it in combination with skype ?
The headset is discoverd and paired within the standard software. But thats all
2 REPLIES 2
rich912
Contributor
The built in Bluetooth uses XP drivers and unfortunately they don¿t support headsets.
The Widcomm drivers do but I am almost certain that you cannot use these drivers with your `built in¿. You will need to use a BT dongle with Widcomm drivers:smileysad:
Go n-éirí an bóthar leat
ZeroBk
It is possible, I have done it myself, but it need some tampering.
Send me an IM on skype (user: nilback) and I'll send you some files and instructions.
There's also a lot of info on how to do it in the hardware section of the Skype forum, but specific for Vaios.
