отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
CPU Fan not working?
StevenF
Посетитель
Hi
I have a Vaio RS226.
I have just run Sisoft Sandra 2004 on it and it say the CPU Fan may not be working.
Does anyone know if it is a variable speed fan on the Viao's, as this may give the false reading that it is not working.
Otherwise, how easy is it to fit a new fan?
Thanks for any help you can give
S
15 ОТВЕТ 15
profile.country.en_GB.title
robpaxton
Исследователь
Sandra will display that the fan is not running if the fan doesn't have a third sensor wire. The fan probably is running.
kee-lo_
Участник
Silly Sandra :tongue:
tellingd
Посетитель
who's "Sandra"?? I thought Stephen started this one.
kee-lo_
Участник
Haha
(I'm sure you know the program)
tellingd
Посетитель
OOps. Silly Dave :laughing:
kee-lo_
Участник
Hahaha
