willy123
ctrl, alt delete
Hi, for some reason ctrl, alt and del doesn't bring up task manager on my fs215b. Is there another command for it that can get me out of sticky situations, and if not is there another way to get into it.
thanks
ps. Sorry I seem to ask so many questions, but really contribute nothing to the board [:">]
12 REPLIES 12
rich912
Contributor
If you right click an empty area of the task bar you will find an option to launch Task Manager.
Go n-éirí an bóthar leat
profile.country.en_GB.title
kee-lo_
rich912
Contributor
Btw Ctrl + Shift + Esc will also launch Task Manager.
kee-lo_
Wow never knew that Rich, thanks
rich912
Contributor
And you can do it with just you left hand, leaving your right hand free for other things¿.
kee-lo_
LOL
GBS
Thanks Rich - a wealth of information.
And now I too can have an idle right hand:smileylaugh: :laughing: :laughing:
willy123
Sorted it out now. I used the forum posted, and found a command from the forum in that link. Typed it in, rebooted and now it works. Thanks for your replies.:smileygrin:
TheCrow
:tired: when i see ur post . i think problem is : your compter detected by Trojan and u cant run task manager
because new trojan ( good programmers ) make disable ur task manager and u must enable it from registery ...
next time if ur pc detected by trojan ... i can help u
