Graphics card
profile.country.en_GB.title
tanto65
Besucher
Graphics card
Hi folks, was wondering if it is possible to change the graphics card in my Vaio FZ21Z as I am sure it is suffering from the Nvidia failure problem. I am in contact with Sony regarding a possible free repair from them as I have argued that they did not notify me either by email or through the Vaio updates that there could be a possible problem with graphics chip/card.The laptop was purchased in March 2008 and although the 4 year ''warranty extension'' has expired they are looking at a free repair. Would changing the card myself be worth it or not? Any ideas on which card I should change to and possible cost?
Thanks for any help,
Dave.
2 ANTWORTEN 2
Blencogo
Hi Dave and welcome.
Unfortunately, you cannot change the graphics card as it is soldered into the motherboard and not economic to replace.
If Sony do a repair, they will completely replace the whole motherboard - which is an expensive repair and not really worth the cost for the user to do themselves as you could probably buy a new notebook for the retail cost of the repair.
If things don't work out with Sony, it is worth investigating a "Reflow" or "Reballing" repair - try Google for details.
Good Luck.
:thinking:
tanto65
Besucher
Thanks for the quick reply Blencogo, will see what Sony decide to do. They are to call us back on Monday with a decision.Wife wants me to go for an Apple Mac as she had probs with another Vaio previously.
Thanks again,
Dave.
