Mouse speed
djwoody
Mouse speed
I have a USB mouse connected to my laptop and I want to make the pointer speed faster.
When I go into Mouse Properties it only shows settings for my 'Alps Pointing device' - the onboard mousepad.
How can I display settings for my USB mouse?
Chris
4 REPLIES 4
rich912
Contributor
Hi djwoody,
Under Mouse Properties (in control panel) do you not have a Pointer Options tab with a Motion – ‘Select a pointer Speed’ slider bar? This adjusts the speed of the USB mouse on my system :thinking:
Go n-éirí an bóthar leat
Thalamus.
Champion
Hi Chris,
When you installed your USB mouse did you load any drivers..?
djwoody
I havent loaded any drivers. Windows automatically detected it as a Logitech USB mouse.
Do I need to install Logitech Mouseware in order to adjust the speed?
Thalamus.
Champion
I installed the drivers etc for my MS Wireless Notebook Optical mouse and I now have both sets of options in my mouse properties..
If you install the Logitech Mouseware be careful you do not loose the touchpad utility though.. :wink:
