problem with function shortcut - no screen brightness control
sid666
hi there.
sorry for newbie question,thats m first time on this forum.
i got VGN-C1S/H, one day i delete some programs from software "add remove programs" list..
probably too much ;/
nowi cannot change brightness of screen using Fn+f5-f6 keys..
someone can help me to replace it?
it drives me crazy a bit 😞
3 REPLIES 3
Blencogo
Hi sid666 and welcome.
You have probably deleted some of the Sony Utilities.
To reinstall them download the Sony Original Utilities Package from VAIO-LINK. Right-click on the downloaded .ZIP file and choose "Extract All". Extract the download into a temporary folder like C:\ Utils. They are the bottom item here: -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-C&m=2413
For the function keys to work you will need to install some of the Utilities in the correct order:
1 Sony Utilities (installer folder 1)
2 Sony Shared Library (installer folder 2)
3 Vaio Event Service (installer folder ?)
And then re-boot your Vaio - you may have to repeat the process as it sometimes needs to be repeated.!
:wink:
sid666
thanx a lot but... still nothing 😞
any others ideas?
sid666
Utils Installer VAIO Power Management
i found resolution! :wink:
thanksa lot for Your help!
now i need to change the space botton because sucks badly and my vaio gonna be lovely again :slight_smile:
