Sony Vaio VGC-JS1E/S - Memory Card Reader not showing in My Computer
profile.country.en_GB.title
assazam
I recently installed windows 7, W7 installed all the drivers I needed except one - the memory card reader isn't showing up in My computer nor is it in the Disk Management section. I cannot seem to find the right driver/software from the support page - please help. Thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
There is no Windows 7 specific Memory Card driver provided so you will have to install the original Memory Card drivers supplied for your model for use with Vista.
There are 3 drivers to install (all start with the name "Memory Card Reader/Writer Driver Ricoh ....") and you can download them from the page of original drivers for your model here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGC-JS1E_S
:wink:
3 REPLIES 3
Blencogo
:wink:
assazam
Ah! Cheers man! I don't know why I didn't think that the old windows drivers would work in W7! Thanks! :smileygrin:
assazam
I just need to bother you with one more thing ... where do I put these drivers? Thanks in advance!
