- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sound keeps dissapearing
i have a sony vaio Pcv rs704 with a recurrent problem with sound everything works normally then sound disappears , every type of sound cd , music file , system sounds . If i turn up the volume from the keyboard I can hear speaker hiss , so the speakers are working , also Itunes won't play at all ie the any music files won't run ( even though no sound , the progress indicator for file playing doesn't move ) while this sound problem persists . I can usually fix the problem with a reboot at which point system sounds return as the computer goes into shutdown so I think it might be a software conflict ,though this fault has persisted after several system reinstallations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No problem.
Was it a DivX?
If so reinstall it, or better get v6
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yeah! i downlaoded the version 6.0!
Its all better now!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
nice smilie Kee lo!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I followed those instructions but could not see wmplayer.exe in task manager , however have downloaded Divx 6 and hope it makes a difference , Thanks for your help , incidentally if not windows media player , what else could be causing it ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What program are you using when this happens?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It happens randomly , I can be surfing the internet and suddenly realise I have no system sounds , or it can happen at anytime , It never happens in the middle of playing a video or audio file , I only usually realise it's occurred If I try to play a file and then the sound doesn't appear
- « Previous
- 1
- 2
- Next »
