which VAIO series is the best option for gaming? plz guide and highlight specifications as well. Thanks
____________________ “Drive your business. Let not your business drive you.”
Sony do not make a 'gaming' Vaio and if you are a serious gamer, you may be wise to buy a dedicated gaming computer.
You can look at the F-Series, the L_Series and the J-Series but there are really all round entertainment media machines rather than designed for gaming.
http://www.sony.co.uk/hub/vaio-laptops
