Hi guys can someone please tell me where can i obtain a set of recovery disc for aVAIO VGN-AR61ZU,Many thanks,Bob.:smileyconfused:
Gelöst! Gehe zu Lösung.
Hi Bob,
You will have to call Support on the out of warranty number.
From the UK the number is 0905 0310006. (Fixed: 0.35£/min) - Have your serial number to hand.
Rich
If you have any success, please tell us, I am looking as well, for AR21, a bit older than yours.
Hey guys, Sony stopped supporting mostly all software support for VAIO as they no longer own the brand, but try your luck tho.
So far we have not exchanged anything, but if and when, I will report here. And if possible make whatever works available. cheers
We are attacking this over here if anyone stops by....
