Hello,
I'm attempting to connect my VGN-FS215Z to my tv, via the docking station.
I want a combination VGA and 3mm audio cable, rather than two separate cables. I found one on mycableshop.com, but I'll have to pay about $60 in total.
Anyone know of any uk shops where I can pick one up?
Wrong forum?
No not wrong, its just a very specialised cable.
Seems the US option may be your only choice, (the exchange rate isnt bad now mind you) I certainly havent seen one even similar, make sure if you do get one its properly sheilded, there's a possibility of some nasy interference if its not.
Sorry its not much use
C
I've seen THIS ONE - expensive if you need a very long cable.
6 foot for £35 or 10 foot for £40 doesn't sound too bad???
