VGN-FS285 wireless configuration
gepad
I don't know if i should post here but I hope you all will be able to help me.
I'm trying to set wireless communication on my VGN-FS285 notebook. It has a intel proSet 2200 BG card with preinstalled 9.0.1.9 driver.
I have a ad-hoc nework (with 128 bits encryption) set. And it's working.
When I tried to connect my sony notebook on this network windows finds the site and connect to it with asking for key encryption. I set the IP address and the gateway (as for my other notebook).
Everything seems fine but when I tried to ping another computer on this little network I get some time out !
I tried to deactivate the windows wireless configuration utility and install the last driver from intel : 9.0.2.0 with configuration utility.
Once again everything seems to be ok but no response to ping and obviously no internet. :cry:
I also tried with 64 bits encryption and no encryption but it doesn't work.
Please help me, is there any special configuration to activate wireless on sony notebooks ? Is my notebooks "broken" ? :thinking:
(Hoping my english is not too bad)
3 REPLIES 3
rich912
Contributor
I am no expert on networking, but until some more useful information is posted I would suggest that you check your firewall settings.
If you are using Norton you should find a Home Network Wizard that will configure the non-routable IP addresses you are using.
Go n-éirí an bóthar leat
gepad
I knew i would forget something !
Norton Internet Security 2005 is installed but desactivated !
I also tried uninstallation before I reinstall all the notebook with backup software !
profile.country.en_GB.title
kee-lo_
I have a feeling Norton is causing you to loose packets to your gateway
