video/tv problems
brendino
video/tv problems
hi clever people out there!
I've had my computer for about 18 months now but recently ive noticed the computer is struggling with video particularly when i want to watch tv. (the tv card being in its docking station)
The audio seems to work fine but the video lags far behind and sometimes stops altogether.
i thought perhaps it may be a codec problem. I check the codecs' with a program called Sherlock Codec Detective and it does say that the Sony DV software Codec (sonydv.dll) is missing or damaged. Could this be the problem?
My machine is a Vaio VGN-A417S
intel pentium M processor 1.99 GHz
1.00 GB of Ram
regard
bren
11 REPLIES 11
Blencogo
Hi bren and welcome to Club Vaio.
You should find a 'spare' in
C:\Program Files\Sony\DVGate Plus\SonyDVShared Library
You could try copying this to
C:\Program Files\Common Files\Sony Shared\VideoLib
and overwriting the existing file.
:wink:
EDIT: Make a backup of the one you are going to replace - rename it sonydll.bak - just in case you are replacing it the wrong way round and the one in DVGate Plus is corrupt !!!
:wink:
rich912
Contributor
I am always a tad suspicious of codec analysing programs. If Blencogo’s suggestion does not have the desired effect then defragmentation of the hard drive may help…
Go n-éirí an bóthar leat
brendino
thanks very much people. The video seems to be much smoother now. im amazed how such a small file/ seemingly unimportant file can make such a huge difference to the performance of my computer.
cheers
LEVELman
Guys the same problem as brendino has mentioned... when I click on a details it shows "The driver for this codec was not found. This probably means the coded was not uninstalled properly." I wouldnt mind about this but I wonder if that can solve choppy DVD playback which I am not the onlyone experiencing here. I have been searching on forums and I have only seen issue with turning off fdd filter, but that didnt help me...
Blencogo
Hi LEVELman,
As you have worked out this must be a codec problem.
Have you tried contacting the official Sony support at Vaio-Link.
As I am sure you know, we are all just enthusiastic Vaio users here on this forum - we are not employees of Sony - so unless we have some members who have managed to find the answer and posted it here, we cannot solve your problem.
:thinking:
LEVELman
No Blencogo I think I rly used wrong words for what I wanted to tell because I know your expert status is given by forum. I ment original Sony employees who are responsible for this. so I am sorry.
Blencogo
No problem LEVELman. No offence taken.
I just wanted to be sure you didn't think we were paid employees who are expected to know everything (fat chance LOL).
:smileygrin: :smileygrin: :smileygrin:
LEVELman
Blencogo just that you know what am I talking about (and that I am not drunk :slight_smile: ) see this: http://img301.imageshack.us/img301/7039/driverproblem9qe.jpg
...reported to Vaio-link, I will post some usable answer when provided by ppl who are payed for providing answers :wink:
Blencogo
LEVELman,
Have you tried copying the updated sonydv.dll from DVGate Plus to windows\system32 as above?
:thinking:
