Ive recently had no option but to wipe the HDD and reinstall Win7 from scratch (long story!).
Ive managed to install all of the drivers except one and I cant identify the one I need.
In device manager under "Other Devices" it says "Base System Device" with the yellow exclamation mark, but neither Windows Update nor Vaio Care/Update have helped.
Which driver do I need ?
It is usually the MemoryStick/SD Card Slot Drivers that get overlooked. Have you installed the 3 Ricoh Memory Card Drivers from here?
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCEB1E0E_WI
However, it could be the SFEP driver. What is the Hardware ID shown in Device Manager under the 'Details' Tab?
Ahhhh thats logical
Thanks, Ill try that.
In the meantime Ive attached an image of the devide IDs
Yayyy, thanks again, it was the memory card
