Partagez votre expérience!
Hello guys, I would like to buy a wireless headset from Sony to use for my PS4 Pro and I couldnt find any information if for example WH-CH500 are compatible with PS4 Pro...
I want a headset that's working without being conected to my controller ( i want both sound and microphone working wireless ).
Any recomandations other than the Gold/Platinum ones ?
You should reach out to PlayStation support for more insight about that since this forum doesn't deal with PS products. Here's the number for them: 0203 538 2665
None of Sony headset is compatible wirelessly because PS4/Pro doesn't support bluetooth headset.
If you wanna stay with Sony, you can go with the Plaitnum headset, but it will still require a usb dongle to plug on your PS4. Gold is ok but built quality and sound not on par with Platinum
