Hi all
if I have a Sony srs-xb31 & a srs-xb10 can i pair them up in the same room and listen to them together to amplify the sound?
i’ve tried to do add the speakers into a group on the sony app & it will just not work 😞
can anyone enlighten me? cheers
Hi Lucy,
I don't think these 2 speakers can be connected. I've just had a look into the help guide and I can see that the SRS-XB31 can be connected to other speakers but the SRS-XB10 is not listed. You can check this here: https://bit.ly/2EBowV2. I've also checked the help guide of the SRS-XB10, but there is nothing that says that you can connect a different speaker to it. You can only connect another SRS-XB10 as stated here: https://bit.ly/2Bqf2YG. So, it's either you can get another XB10 and connect both of them or an XB21,XB31, XB41, XB20,XB30 or XB40 to be able to connect to the XB31.
Cheers,
The_Black_Rose
Hi Lucy,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Hi Lucy,
Cheers,
The_Black_Rose
