I love my SRS-XB20, great device!
The XB20 works well on my up to date Windows 10. After pairing the following devices become available:
1. Speakers SRS-XB20: works ok
2. Microphone SRS-XB20 Hands-free: works ok
3. Headset Earphone SRS-XB20 Hands-Free: no sound!
For Windows, the device looks healthy: when testing the sound indicator lights up but no sound from the device.
I tried: checked device volume, re-install BT drivers, pairing, un-pairing removing all other BT devices.
The result stays the same.
Ultimately I'd like to use the XB20's handsfree features for WebEx and Skype.
Hi jhflkjgd,
Please take a look at the SRS-XB20 Help Guide here: http://bit.ly/2m7txsO
If you require any further help, please contact Support here: https://services.sony.co.uk/supportmvc/en/Contact/Email
Hope this helps!
Thanks,
Sean Mc
Have you found a solution for this? Seems a little difficult to make this work on windows 10. When I use this function on my Phone, It works flawlessly.
