- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have NW-A45. I find that the Audio volume output is very low when the output is from a wired connection compared to the Bluetooth connection. Is there any settings which can increase the wired connection output. As I do not have bluetooth in my Audio system, I have to use a wired connection unfortunately.
thank you in advance.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm pretty sure what you're experiencing is the effect of AVLS which is an automatic volume limit that doesn't affect Bluetooth output. Checkout the Help Guide page for it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sony' s Walkman have to follow europeen regulation for audio output which is quite low if you use wire connection. To bypass it you will have to use google ^^ to look for the way to do it
Can't help you more on this official forum
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You can fix the volume limitation by using the Sony NW Dest Tool. It's not difficult & I can confirm that it works as my UK spec NW-A45 is set to USA setting, the sound is louder & bass is fuller. Just google "SonyNWDestTool Rockbox.org" or go straight here - https://www.rockbox.org/wiki/SonyNWDestTool .
This is working 100% guaranteed.
Thanks
