The volume control on my SRS-BTX300 does not work.
alexcalderhead
The volume control on my SRS-BTX300 does not work, are there any suggestions on what the problem is?
3 REPLIES 3
Anonymous
Not applicable
@alexcalderhead Did you check if it's jammed?
alexcalderhead
It doesn't feel jammed, I can feel the switches under the volume rocker working
Anonymous
Not applicable
Hey @alexcalderhead
In this case, you will need to contact Sony to arrange an inspection for the speakers if possible.
