Walkman BCR NWW270. Software download- now it will not work !!!
Destinysheba
Hi
   I have been really happy with my walkman, after downloading a softwear update for the first time, now it will not switch on. The battery is full and all that happens when i press button to switch it on,  is the green light flashes about four times and nothing happens. I wish i had never done the softwear update <:(
   Please can you help me as soon as possible
Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
Destinysheba
I found a solution to this problem that worked for me and my unit is now functioning again <:)
It is a bit random but what i did was - Used a tooth brush and cleaned the contacts on the unit and on the cradle ( accessible by pushing in arm on cradle to bring up contacts ). Jiggled the usb in and out a couple of times on the laptop and made sure the conection was sound. I then deleted the music files on the unit, updated the Media Go software and hey presto, it would switch on so then transfered my music back on PHEW ...All back to normal <:)
I won't be updating it again, i think.
Hope this solution works for others too
Good luck
Destinysheba
4 REPLIES 4
Destinysheba
The correct product number is:- NWZ-W273
 Destinysheba
Pascale_F
Moderator
Hi Destinysheba,
Welcome to the community.
With regards to the download for the NWZ-W273, please follow the Mac instructions here or the Windows instructions here, and let us know how you get on.
Thanks,
Pascale_F
Destinysheba
Hiya Pascale_F
   Thank you for your reply.
The original problem that has occured of my unit not working/switching on was when i downloaded and installed Firmwear 1.10  I have not had any problems before this.
Is there anyway i can solve this please
Many thanks
Destinysheba
Destinysheba
Good luck
Destinysheba
