WH-1000XM2 Volume increase during idle
profile.country.UA.title
Bonuscore
Hi.
I have an issue with WH-1000XM2. After idle time (5-10 min) within the Bluetooth range of phone (either Android or iPhone) the volume of headphones raises to ~+50%. Power OFF and ON fixes it, but if I forget to do that and start to play music, my ears will "bleed". Please help.
Tags (1)
3 REPLIES 3
Vanilla_
Contributor
Hi Bonuscore,
This is very strange behaviour. Have you tried to update the firmware version of the headset? You can follow the steps here: https://bit.ly/2C78C0Q
Also, you can try to reset it to the defaults following the steps in this link: https://bit.ly/2LYK9j0
Let us know if this resolves it.
Vanilla_
Bonuscore
Current Firmware is the latest - 2.0.1
I've tried to Turn Off and On DSEE HX, Repair headphones with smartphone, performed both Soft Reset and then Hard Reset.
The issue is still reproducible, unfortunately.
Vanilla_
Contributor
Hi Bonuscore,
I'd recommend that you send your headset to Sony service centre to get it inspected. You'll find their contact details here:
https://bit.ly/2byAqx1
Regards,
Vanilla_
