Wh-Ch500 Headphones, lost voice assistance.
Efarr1
I have been using these for around a month, and after charging them today, when I turn them on, I have no voice assistance to say 'Power on' or to tell me my Bluetooth is connected. Everything else works fine, I just have lose all voice assistance when powering on or off. I have tried looking for answers but can't find anything that could help.
9 REPLIES 9
EdwinaU
Moderator
Hi, and welcome to the community.
There's some information about voice assist in the help guide here that should help.
Let us know how you get on.
Best wishes,
Ed
Efarr1
It's not Siri, I am using android.
I mean the voice that speaks when you manually turn on and off the headphones, eg the voice says 'Power On' inside the headphones. That has stopped completely, and also now when I turn up the volume using my phone, the volume coming through doesn't match what I have it set as.
For example if I have it 40% of the way up my volume bar, it's like I have it at 100% and then the more I go up the bar it alternates between getting quieter and louder. I can't think of a better way to describe it
IamNic
Hello @Efarr1,
have you tried to reset your headphones as described here: http://helpguide.sony.net/mdr/whch500/v1/en/contents/TP0001613429.html
- Nic
Efarr1
Yeah, I've tried that twice already, and still nothing.
Nicoalex02
I have the same issue i donno if is an firmware update or a malfunction.
I need help.
profile.country.SE.title
Psych75
I have exactly the same problems.
Efarr1
I ended up taking them into a Sony store and the rep said that its an issue that can't be fixed and that I should just return them. So I did and got a different brand of headphones. I know this might not be much help to you, but it's what ended up happening for me.
Efarr1
DrBoothy
Exact same issue here. Super annoying.
