Hey Guys
I am having a wierd and annoying issue with my new Xperia X
When I put the phone on to charge overnight a couple times when i got up during the night I have noticed that the screen is on constantly on.
A few times when I wake up in the morning and I check my phone the screen was on too.
I have checked that Daydream is off and that Developer options > Screen awake is disabled too. The phone is only a few days old.
Any ideas?
Thanks
Ok just an update.
I was using a power lead exention where the charger was plugged into.
Last couple night i have been plugging directly into wall socket and no issues.
Strange.
@Bobo13 Have you changed settings under developer options? There is something called stay awake.
Hi
As I have mentioned in the OP. I have checked this.
Really sorry for not noticing. What about safe mode? Can you try to charge your device like that?
No worrries.
How do I get into Safe Mode?
I have left you a link in my upper post. You can get to safe mode by pressing the power button, then long pressing turn off. A message will pop up.
Thanks I will try this.
Okay I just did a factory reset instead. As I was having other issues with Apps crashing.
Hoping this fixed it. Will update.
Ok, strange as it is a new device and you already crashed it, just kidding
@Bobo13
Ok unfortunatley the factory reset has not resolved it
I havent installed any 3rd party apps on the device aswell so looks like I have a faulty phone. What a shame
