My phone is Sony XA android 6.0. I can't find the "double tap to sleep/wake" button. What should I do?
Hi @seuniewithlove, welcome to our forum!
Double tap to wake is not supported in the Xperia XA, but you should be able to find the double tap to sleep function if you tap and hold on an empty area of the home screen > tap on "Settings" in the bottom right corner > activate "Double tap to sleep".
I hope that helps!
Found it! Thank you so much for the help. I'm worried of my on-off button that's why I badly wanted the double tap to sleep. Thank you so much!
Hi again @seuniewithlove,
I'm sorry for the late reply but I'm very glad to hear that you found the setting!
Have a nice day and let me know if there is anything else!
