The hotspot doesn't work never
They write :Error occurred during tethering can anyone help me
Try booting in safe mode and turn Hotspot in safe mode to check it
For booting in safe mode
Hi @Bilal7, sorry to hear about this.
Has there been any change after trying what @Satyaveer suggested? If there has been no change, try resetting the network settings in your device.
Do note that this will delete saved Wi-Fi networks and remove previously paired Bluetooth devices.
Let us know if that helps or if you have already solved it!
